| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
| Date Logged & Current Version | Oct 2023 23.00.00.230 |
In the text output, as part of each stress summary, results are given at each node, eg as follows:
Point (Stresses in N/mm2 , Ratchet in deg C ) Usage Name EQ.9 EQ.10 EQ.11 EQ.12 EQ.13 Ratchet Leakage EQ.14 Factor Notes ------ -------- ------- ------- ------- ------- ------- ------- ------- ------- ----- *** Segment A begin *** A00 Stress 50 140 884 - - - 140 442 0.0129 Allowable 142 283 - - - - - - - Ratio 0.356 0.495 - - - - - - - Load Pair 55-56 52-54 52-54 - - - 52-54 52-54 -
Why do the results give a load pair for equation 9? Equation 9 should not be ranging between load cases.
Agree the range for Eqn 9 is not needed. This was added by request to synch back to the fatigue report to figure out what load cases was causing the biggest problems. If not interesting for your review, suggest to ignore Eq 9 ranging.
ASME BPV-III-1-ND, AutoPIPE Nuclear Piping Code FAQ
