| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | General | ||
| Original Author: | Ranjana, Bentley Technical Support Group | ||
How to set additional grid lines in RCDC?
RCDC automatically detects all the grids along column lines when we import the analysis model. But, after that if we need some additional grids, we can add them easily. To add new grids we should go to
Modify > Grid Lines and right click on the new window to add grids at different locations;
We can easily add, delete or hide/unhide grids from this settings. It has also an option to include inclined grid using the inclined option.
