Release Date: 19th January 2022
Release Name: Structural WorkSuite Hub CONNECT Edition Update 1
Release Version: 12.01.00.55
This version of Structural WorkSuite Hub contains general stability fixes as well as access to Ideas Portal and Product News and Announcement Feeds accessible.
Ideas Portal
Allow you (the user) to provide us valuable feedback that will steer Structural WorkSuite Hubs future development. Feel free to submit an idea by clicking on "Add a New Idea"
Allows you to quickly stay up to day with recent product news and announcements. Check regularly to watch Coffee Corners, Tips and Tricks, On-Demand recordings and more!
Download Instructions
Structural WorkSuite Hub can be downloaded at the link here, or from Bentley Cloud Services. After signing into the CONNECTION Center, select Software Downloads under My Support. Once on the Software Fulfillment page, the installer can be located by performing a search on “Structural WorkSuite Hub”.
For all users (including existing users), Structural WorkSuite Hub will require a one-time download from either of the above methods. After which, update to Structural WorkSuite Hub itself would be presented as an update option within Structural WorkSuite Hub itself.
Subscription Entitlement Service (SES)
This product version utilizes Subscription Entitlement Service, which is not supported by SELECT activation key(s). SES is a free service, featuring new behavior to enhance your organization’s user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
