| Product(s): | Microstran | ||
| Version(s): | Connect Edition | ||
| Environment: | Windows 10 | ||
| Area: | Error, Not supported | ||
| Defect Number: | |||
| Original Author: | Global Technical Support | ||
When I select the help button (“?”) in any Microstran Connection Design dialogue boxes and point to a field, I get the error message.
Not only in Microstran Steel connection design but in all dialogue having help sign (?) does report this error. .
Error opening Help in Windows-based programs: "Feature not included" or "Help not supported" . The Windows Help program is not supported in Windows 10 and later.
The Windows Help program is available for Windows Vista, 7, 8 and 8.1 only.
It is recommended to discontinue using the Windows Help application.
