Process to re-orient pile caps
 Product(s):STAAD Advanced Concrete Design
 Version(s):All
 Environment: N/A
 Area: Concrete Design
 Subarea: Pilecap Design
 Original Author:Abhisek Mandal
Bentley Technical Support Group
How to change the orientation of the pile cap we get after autodesign?
RCDC finds the number of pile with first auto design command and show the pile cap orientations. In this step we can change the orientation of the pile cap easily. Like we can rotate the pile cap clockwise or anticlockwise to get the desired orientation. To do that we need to select the column and right click in the Layout window as shown below. It will provide the required options.
