Q. Can I install AutoPIPE on a VM (Virtual Machine)?
Product(s): AutoPIPE
Version(s): ALL;
Area: Install
Date Logged
& Current Version
Feb. 2018
11.02.00.10
Problem:
Yes, AutoPIPE can be installed on a VM. There has been no reported issues with running AutoPIPE because of being installed in a VM.
What is a VM?
According the WIKIpida:
In computing, a virtual machine (VM) is an emulation of a computer system. Virtual machines are based on computer architectures and provide functionality of a physical computer. Their implementations may involve specialized hardware, software, or a combination....
Virtual Machine Software:
There a many different software makers and programs that create a VM, therefore Bentley cannot provide detailed assistance in setting up the actual VM, However, we will be happy to assist with typical installation of Bentley applications. Suggest to contact the VM software technical support for installing instructions and settings recommendations of the VM.
Installing AutoPIPE:
The VM must meet the minimum requirements set forth in the AutoPIPE version's readme file. Then install AutoPIPE as if it was a normal computer.
Licensing AutoPIPE:
The VM must support licensing of Bentley application through BLT (Bentley Licensing Tool) supported by SES (Subscription Entitlement Service). Review the following information and abide by the requirements:
User Profile / Permissions
As with an installation of AutoPIPE on a normal computer, the application will read / write to many folders. Thus, the users will still need permission to reads / writes data as needed by the application in a normal setting.
Do I need to have internet connection?
Yes and No.
First and foremost, acquire the software. The software is only available by downloading it from Software Downloads web site, which is accessible from a link inside of Connect Center (see download page here). Therefore, internet connection is required to download the software. After downloading the software it can be transferred by any means to the computer that does not have internet connection.
Next, depending on your licensing, If you have a node lock license, then No you do not need an internet connection, see WIKI here.
However, if you plan to share licenses among a group of people, then Yes you do need an internet connection to log into Connection Client in order to get your entitlements.
If you have any troubles with licensing the application, please contact Bentley Licensing department for assistance by phone or log a case.
Download, Install, Release Note information
