| Product: | RAM Structural System | ||
| Area: | Files |
An error "Unable to find the requested .Net Framework Data Provider. It may not be installed, will prevent to open any file in RAM Structural System:
Install SQLCE 4.0 as it is likely not installed or damaged.
