| Product(s): | ISM Revit Plug-in | ||
| Version(s): | All | ||
| Area: | Import/Export |
The ism file based iTwin using iTwin analytical synchronizer continues to be a free product.
The second machine is using iTwin Analytical Synchronizer and has no recourse to STAAD. It's FREE to be downloaded.
ISM Revit Plugin also free and to be downloaded from https://softwaredownloads.bentley.com/en/ProductDetails/1858?packageid=32361
and https://softwaredownloads.bentley.com/en/ProductDetails/1963?packageid=26819 respectively.
