Release Date: Tuesday, 13th March 2018
Version: ISM Revit Plugin CONNECT Edition
Version Number: 10.02.02.26
Download Instructions
The ISM Revit Plugin can be downloaded from the Bentley store here. For Bentley SELECT subscribers, the ISM Revit Plugin can be downloaded from Bentley Cloud Services here. After signing in to the CONNECTION Center, select Software Downloads under My Support. Once on the Software Fulfillment page, ISM Revit Plugin installers can be located by performing a search on "ISM Revit".
Special Notices
The installation of ISM Revit Plugin CONNECT Edition will automatically uninstall any previous versions that were installed. This version of ISM Revit Plugin can be run in Revit 2016, 2017, and 2018.
ISM Revit Plugin requires ISM and Structural Synchronizer (both of which are installed with Structural Synchronizer). More information on ISM and Structural Synchronizer can be found here.
New Features
No new features were added to ISM Revit Plugin 10.2.02.26.
Error Corrections
ISM Rebar import from Ram Concept – Previously, in certain circumstances US bar sizes were transferred into Revit incorrectly and defaulted to bar size #1. The correct bar size is now assigned (766177).
Concentrated Surface Rebars – Concentrated Surface rebars with rebar count of one were updated to rebar count of 2. Solution involves filtering for these type of ISM objects on import, as Revit’s Path Reinforcement object require a minimum of 2 bars (818408).
Import Crashing Revit - Certain rare invalid arrangement of loads and surface elements would cause import to crash (722006, 721355).
Studs imported from Ram Structural System – Studs imported from Ram Structural System would have its stud count shown separated with semicolons rather than commas (563440).
About ISM Revit Plugin
The ISM Revit Plugin enables a round trip exchange between Revit® and Bentley’s Integrated Structural Modeling (ISM) format, therefore also enabling a round trip exchange between Revit and any other ISM-enabled application. RAM Structural System, RAM Concept, and STAAD.Pro are examples of applications that are ISM-enabled and can interoperate with Revit with the help of the ISM Revit Plugin.
The ISM Revit Plugin adds commands to Revit that allow ISM repositories to be created and updated from Revit, and allow Revit to create and update ISM repositories. The ISM Revit Plugin is dependent on ISM and thus Structural Synchronizer must be installed on the computer.
