ISM Revit Plugin CONNECT Edition V11.01 (SES) Release Notes
Release Date: 8th November 2019
Version: ISM Revit Plugin CONNECT Edition V11 Update 1
Version Number: 11.01.00.07
Download Instructions
ISM Revit Plugin can be downloaded from Bentley Cloud Services here. After signing in to CONNECTION Center, select Software Downloads under My Services. Once on the Software Fulfillment page, ISM Revit Plugin installers can be located by performing a search on "ISM Revit".
Special Notices
The installation of ISM Revit Plugin CONNECT Edition will automatically uninstall any previous versions that were installed. This version of ISM Revit Plugin can be run in Revit 2018, 2019, and 2020.
ISM Revit Plugin requires ISM and Structural Synchronizer (both of which are installed with Structural Synchronizer). More information on ISM and Structural Synchronizer can be found here.
New Features
In this update, we added support for REVIT 2020.
