ISM Revit Plugin 10.2 Release Notes
Release Date: Thursday, September 7, 2017
Version: ISM Revit Plugin CONNECT Edition
Version Number: 10.02.00.19
Download Instructions
The ISM Revit Plugin can be downloaded from the Bentley store here. For Bentley SELECT subscribers, the ISM Revit Plugin can be downloaded from Bentley Cloud Services here. After signing in to the CONNECTION Center, select Software Downloads under My Support. Once on the Software Fulfillment page, ISM Revit Plugin installers can be located by performing a search on "ISM Revit".
Special Notices
The installation of ISM Revit Plugin CONNECT Edition will automatically uninstall any previous versions that were installed. This version of ISM Revit Plugin can be run in Revit 2016, 2017, and 2018.
ISM Revit Plugin requires ISM and Structural Synchronizer (both of which are installed with Structural Synchronizer). More information on ISM and Structural Synchronizer can be found here.
New Features
The following enhancements were added to ISM Revit Plugin 10.2.
Import of Reinforcing into Revit®
Reinforcing objects in ISM repositories are now imported into Revit when creating a new Revit model from an ISM repository and when updating Revit models with changes in an ISM repository. As with previous versions of ISM Revit Plugin, this release also supports the export of reinforcing from Revit to ISM. All types of ISM reinforcing are supported in the import. This enables productive workflows between Revit and products such as RAM Concept, where 3D reinforcing designed in RAM Concept can be transferred into Revit for 2D documentation and scheduling.
An overview video of this new feature is available here. A detailed wiki on producing slab rebar drawings in Revit using a RAM Concept model is available here.
Compatibility with Revit 2018
This version of ISM Revit Plugin is now compatible with Revit 2018, with continued support for Revit 2016, and 2017.
Load Case Mapping Enhancements
New features have been added the give the user more control over how ISM load cases are mapped to Revit load cases. The ISM Revit Plugin shared settings file now includes a mapping table for load cases. This gives you control over how load cases in ISM repositories are mapped to Revit load cases. This may be edited for any existing shared setting db files that have already been set up.
Error Corrections
No error corrections were included in this release of the ISM Revit Plugin.
About ISM Revit Plugin
The ISM Revit Plugin enables a round trip exchange between Revit® and Bentley’s Integrated Structural Modeling (ISM) format, therefore also enabling a round trip exchange between Revit and any other ISM-enabled application. RAM Structural System, RAM Concept, and STAAD.Pro are examples of applications that are ISM-enabled and can interoperate with Revit with the help of the ISM Revit Plugin.
The ISM Revit Plugin adds commands to Revit that allow ISM repositories to be created and updated from Revit, and allow Revit to create and update ISM repositories. The ISM Revit Plugin is dependent on ISM and thus Structural Synchronizer must be installed on the computer.
