ISM Revit Plugin 10.03 Release Notes
Release Date: October 10, 2018
Version: ISM Revit Plugin CONNECT Edition
Version Number: 10.03.00.08
Download Instructions
The ISM Revit Plugin can be downloaded from the Bentley store here. For Bentley SELECT subscribers, the ISM Revit Plugin can be downloaded from Bentley Cloud Services here. After signing in to the CONNECTION Center, select Software Downloads under My Support. Once on the Software Fulfillment page, ISM Revit Plugin installers can be located by performing a search on "ISM Revit".
Special Notices
The installation of ISM Revit Plugin CONNECT Edition will automatically uninstall any previous versions that were installed. This version of ISM Revit Plugin can be run in Revit 2017, 2018, and 2019.
ISM Revit Plugin requires ISM and Structural Synchronizer (both of which are installed with Structural Synchronizer). More information on ISM and Structural Synchronizer can be found here.
New Features
The following enhancements were added to ISM Revit Plugin 10.3.
Support for Revit 2019
Support for Autodesk® Revit version 2019 has been added. This release is compatible with Revit 2017, 2018, and 2019, and is no longer compatible with Revit 2016. This release requires Structural Synchronizer CONNECT Edition Update 1 or a later version.
Export of Isolated Foundations
The ISM-Revit Plugin now allows the import of Isolated Foundation (Rectangular Surface Members with only 1 column support) to be imported as the Revit Family- Isolated Foundation as opposed to previously imported Foundation Slab. This enhancement allows easier production of foundation schedules in Revit. The imported rebars are Structural Rebar Objects and can be tagged for drawing production purpose.
Error Corrections
Revit floor/deck span direction not exported to ISM, all decks have R-axis = 1,0,0– Evident in models containing slab with one way floor type other than 0 degrees. (907723).
Repository path field does not reflect the changes done by means other than file picker– Found in Operation Settings page of ISM file input field. (923278).
About ISM Revit Plugin
The ISM Revit Plugin enables a round trip exchange between Revit® and Bentley’s Integrated Structural Modeling (ISM) format, therefore also enabling a round trip exchange between Revit and any other ISM-enabled application. RAM Structural System, RAM Concept, and STAAD.Pro are examples of applications that are ISM-enabled and can interoperate with Revit with the help of the ISM Revit Plugin.
The ISM Revit Plugin adds commands to Revit that allow ISM repositories to be created and updated from Revit, and allow Revit to create and update ISM repositories. The ISM Revit Plugin is dependent on ISM and thus Structural Synchronizer must be installed on the computer.
