Q. Setup XM Licensing Manually for AutoPIPE
Product(s):AutoPIPE
Version(s):All
Area: License
Date Logged
& Current Version
Mar. 2015
09.06.01.11
Use the following steps to setup Bentley software licensing manually:
Note: video of instructions at bottom of page
Step #1:Start Bentley's LMT (License Management Tool) program
There are a number of methods to starting this application
a. From within the application:
AutoPIPE CONNECT 10 and higher: Select File> License Management Tool...
AutoPIPE V8i 09.06.01.xx: Select File> License Management Tool...
AutoPIPE V8i 09.05.xx.xx and lower: Select Tools> Settings> License Management Tool...
b. From Windows Start Menu:
select the Windows Start button, typically found in the lower left corner of the screen, in the search area type "License Management Tool"
Note: this option is not available when installing AutoPIPE CONNECT 11.0 and higher
c. From Application's Menu Group:
Example, AutoPIPE menu group: select Windows Start button, typically found in the lower left corner of the screen, Select "All Programs", navigate to Bentley Engineering> AutoPIPE V8i Select Series> License Management Tool.
Step #2: Enter Server Name and Site activation Key
Within LMT, select Tools> Options> a dialog will appear, enter the "Server Name" and "Site Activation" Key Exactly as provided.
Note:
1. if you do not know your Serer Name and Site Activation Key information, click here.
2. For hosted licenses, Server name = selectserver.bentley.com
Verify entry and connectivity, press the "Test connection" button:
The following should have appeared:
SELECTserver and Activation Key verified.
If true, Great !!! got to Step #3. else continue reading below:
If the following appears:
Server does not support this Activation Key.
Press OK button,
There are only 2 reasons for this failure:
A. Computer not connected to the internet, (FIX: confirm internet connection)
B. One or both of the Server name / Site Activation Key were entered incorrectly, (FIX: confirm information entered).
IMPORTANT: Only when the "TEST Connection" button can be pressed and the Verified screen appears can any of Bentley applications become licensed. Contact Bentley On-Site Admin or Bentley Licensing / SELECTServer Group for assistance.
Step #3: Confirm AutoPIPE edition(s) available in LMT
Press Ok button to close the Options pop-up window and select the License Checkout tab, shown below. The upper window will have a list of Bentley applications with the current number of available licenses on your SELECTserver. This list can also be controlled by any Bentley SELECTserver User / Application Checkout restrictions imposed by your companies Bentley On-site Admin.
Note: only applications listed with available license >0 in LMT can be activated.
Example: if AutoPIPE Nuclear was not listed in LMT or the number of available licenses for that application was 0, then DO NOT try to start AutoPIPE and activate the Nuclear edition, AutoPIPE will revert to DEMO mode.
See Video that demonstrates steps above:
Step #4: Close LMT
Licensing is completed, Close LMT!!!
Continue to Step #4: Start AutoPIPE
AutoPIPE CONNECT 11.xx
AutoPIPE CONNECT 10.xx
+++important+++ only applications listed in LMT with available number of license >0 can be activated.
Download, Install, and License AutoPIPE CONNECT 10.00.xx.xx and higher
