Comments, Questions, and Answers on AutoPIPE help example: Ball and Socket Joint:
Q1. In step #3, why was a pressure thrust area of 28.89 sq. in necessary?
Answer:
See the last sentence in this paragraph:
"The area entered assumes that the ball joint has an internal sleeve (based on Di = 6.065")."
