Attention.
1. Please see the following AutoPIPE help section.
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches>
This help has been provided in order to give users ideas for modeling typical piping arrangements. The steps shown in each example should not be taken as the only method available to create models. In addition, the intent of the examples is to present ways to create adequate models of specific piping components for analytical purposes.
Anchors Bends
Cuts Flexible Joints
Frames Hangers
Nozzles Pipes
Reducers Rotating Equipment
Supports Tees
Valves Vessels
2. For general information about Tee dialog settings - see program help
Video Tutorial on modeling a Tee
In AutoPIPE select Help> Tutorial> First Tutorial> Creating a New Model> Insert a Tee
Model Different Types of PIPING Components
