| Version(s): | ALL |
| Area: | General |
| Date Logged & Current Version | Nov 2023 44.00.00.111 |
Nozzle check as per table C5.1.2.2 CODAP 2010 Div.2 Add 10/12 is not done, Why?
AutoPIPE Vessel performs the check of Minimum distance between an opening and wall discontinuity as per applicable configuration with respect to Table C5.1.2.2.
Incase criteria given in the Table C5.1.2.2 does not meets with the input given, then software will show an error. See snap below from report for reference.
