C. As Per CODAP
Nozzle Calculations as per CODAP
Calculate allowable stresses for CODAP
Modulus of Elasticity values for CODAP, Table C1.6.5
Calculate allowable stress for ambient and design temperatures
Allowable Compressive Stress (fc) as per CODAP
MDMT calculation not available in the report for certain materials
Calculate hydro-test pressure per CODAP Div. 1 used for Shell and Tube Heat Exchangers
BEW heat exchanger designed to CODAP 2005, calculate to § C7.A9.6 (sliding head exchanger)
Settings affecting material safety factor
Nozzle check as per table C5.1.2.2 CODAP 2010 Div.2 Add 10/12
Stiffening rings at the Cone-Shell junctions under internal pressure
See Also:
Calculations
Support Solutions & FAQ's
Bentley AutoPIPE Vessel
