| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Isometric |
| Date Logged & Current Version | Nov 2023 23.00.00.230 |
When AutoPIPE model is saved as Stress Isometric to AutoCAD drawing format, all the dimensions are displaced or scattered everywhere.
Example:
This is a known issue (1287210) not with AutoPIPE but with OPIM. This will be fixed in a future version of the application. The only workaround at this time is to manually manipulate the drawing elements as needed.
If you encounter this issue, please log a new case and reference this WIKI page
Stress Isometric Trouble shooting
