Product Version |
Product | Bentley AutoPIPE yearly |
| Version | v.23.00.00.230 |
| Language |
| Date Posted |
Released March 2023
| Platforms |
Microsoft Windows 10 x64 Professional or higher |
| .NET Framework |
4.7.2 |
| Licensing |
Subscription Entitlement Service |
| OPIM |
CONNECT Edition Update 11 - 10.11.00.175 (only) |
Description:
Bentley AutoPIPE Yearly edition is a stand-alone, engineering application for the calculation of piping stresses, fatigue stresses, fluid transient, bowing or thermal transient analysis, flange or pipe support design, and equipment nozzle loading analysis under static and dynamic loading conditions. In addition to 30+ piping codes, AutoPIPE incorporates ASME, JSME, British Standard, European, API, NEMA, ANSI, ASCE, AISC, UBC, GOST and WRC guidelines and design limits to provide a comprehensive analysis of the entire system.
For additional information on release notes and system requirements see the Release Announcement and ReadMe (EN) documents.
Subscription Entitlement Service:
This product version utilizes Subscription Entitlement Service, which is not supported by SELECT activation key(s). Subscription Entitlement Service features new behavior to enhance your organization's user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
The Bentley Support Policy describes the phases of eligibility for specific support services, and provides the current and planned support status for all versions of Bentley desktop applications , ProjectWise servers and services, and License Administration Services. Understanding the benefits and the support status for your software will help you to proactively manage your licenses for your organization.
| What is New & Changed in AutoPIPE |
| Detailed Readme: |
Note:
1. Readme file contains limited amount of information about errors / enhancements, only QA&R members have access to detailed Error Reports
| Download, Install, and License Procedure: |
See procedure here
| Validation Certificate: |
See copy of Software Validation Certificate by starting AutoPIPE, select Help Ribbon, Software Validation certificate icon.
| Known issues with other Applications: |
Image the testing time and effort required to certify that AutoPIPE works with every business program available on the planet in every possible configuration. At this time, May 2023, there are no known issues with running AutoPIPE and other applications like MS Office, various Cad Software, etc...
If the someone runs into any problems, please log a new case and provide evidence that AutoPIPE is at fault. If AutoPIPE is to blame, our development team will investigate and come up with a solution.
