2. Feature Articles
Product(s):
STAAD Advanced Concrete Design
Version(s):
Connect Edition
Environment:
Area:
Concrete Design
Subarea:
Original Author:
Bentley Technical Support Group
Technical Documents
- Detailed Explanation and difference between the 2 methods available in SACD/RCDC
BS-EN-02-2004 - Clauses
from the code used for the design and its insights
Quick Feature Videos
and its settings in RCDC
General flow of Column and Wall
Design in RCDC
General flow of
Eccentric Footing
Design in RCDC
Calculation of
Bearing Pressure as per BS EN 1997
for Drained and Undrained Soil type
General flow of
Design of GRAVITY Columns
in RCDC
Integrated
Design flow of exporting RAM Structural System
Model to RCDC
Functioning of
Shift of CG Option in RCDC for Columns
with different sizes at different levels
Working of
Update Analysis Function
in RCDC
Verification Examples
Pedestal Design
for Steel Columns
Water Tank Design
Calculation of Consideration of
LOSS OF CONTACT (LOC)
for Footings
Joint Checks - Flexure and Shear as per IS 13920 - 2016
Shear Wall Design with Boundary Elements
Update Design Functionality
for Columns
