| Version(s): | All | ||
| Area: | OpenSTAAD | ||
| Subarea: | Loading | ||
Problem Description:
How to add LOAD LIST command using OpenSTAAD function
You can use function CreateLoadList for the task.
Function 1: CreateLoadList
This function adds LOAD LIST command.
Parameters:
[Input] varListType: Load list type: 0 and 1 for load list and load envelope list, respectively
[Input] varLoadCaseList: Load case reference ID(s) or Load Envelope ID(s)
VBA Syntax:
Set objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")
Dim varListType As Long
Dim varLoadCaseList_for_Loadcase(2) As Long
Dim varLoadCaseList_for_Envelope(1) As Long
varListType = 0 'For Load cases/ Load Combination case
varLoadCaseList_for_Loadcase(0) = 6 'Load Case Number/ Load Combination Number
varLoadCaseList_for_Loadcase(1) = 7 'Load Case Number/ Load Combination Number
varLoadCaseList_for_Loadcase(2) = 8 'Load Case Number/ Load Combination Number
objOpenSTAAD.Load.CreateLoadList varListType, varLoadCaseList_for_Loadcase
varListType = 1 'For Load Envelope
varLoadCaseList_for_Envelope(0) = 1 'Load Envelope Number
varLoadCaseList_for_Envelope(1) = 2 'Load Envelope Number
objOpenSTAAD.Load.CreateLoadList varListType, varLoadCaseList_for_Envelope
Output:
