Feature 1063484:
Add high pressure calculation based on ASME B31.3 chapter IX method
Feature 1021924:
Add ASME B31.3 - 1996
Feature 670542:
Update ASME B31.3 - 2020
Feature 1264677:
Update ASME B31.3 - 2022
633755 - Enhancement:
Add option to switch between ASME B31.3 eq. 3a and 3b
Add ASME B31.3-2016
566491 - Defect:
Add feature to specify user defined Sus In / Out plane moment index at a node point
334683 - Defect:
Non-linear analysis is incorrectly flagging supports as lifting off
156301 - Enhancement:
B31.3 Code Fig 323.2.2B MDMT reduction based on stress ratio
138562 - Enhancement:
Add ASME B31.3-2014
121414 - Enhancement:
B31.3 Para 323 Avoiding Impact Test Requirements Warning
110599 (CAE-CR- 3268) - Enhancement:
Add fatigue analysis for ASME piping codes
CAE-CR-10741 - Enhancement:
B31.3-2010: Add functionality for user to enter axial and torsional SIF
CAE-CR-10585 - Enhancement:
Add B31.3 2012 piping code
CAE-CR-10311 - Enhancement:
Online help for Use Alt. Occ. Allow must include a table for ASME B31.3 2010
Piping Codes Enhancements & Defects
