| Version(s): | ALL |
| Area: | General |
| Date Logged & Current Version | Dec 2023 44.00.01.014 |
How to model transition opening offset?
We can shift a Transition Opening in AutoPIPE VESSEL.
First open the Elliptical head on which nozzle is mounted and check option "Axis Offset", then enter appropriate value in "Bottom Generator Offset".
You will see the nozzle in offset position.
