| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version | Dec 2023 23.00.00.230 |
Provide more information about nozzle element, ASME field requirements in AutoPIPE
To begin comprehending any AutoPIPE dialog requirements, click the Help button located in the lower right corner and go through each help subject individually. Answers to many common questions would be straightforward:
Example,
Question: Could you please show a picture what the Slope offset is in the nozzle ASME?
Answer:
Since this question is directly related to dimensional value of the nozzle's configuration, refence the Configuration help heading for details related to each configuration A,B,C,D. In this case, select the hyperlink for "Configuration A/B/C/D", at the bottom of the help section is reference to See Also: "Figure NB-3643.3(A)-1 Branch Connection Nomenclature", selecting that hyperlink shows you the information about the various configurations with reference to Offset dimension. If this viewing area is to small, search AutoPIPE help for "Figure NB-3643.3(A)-1 Branch Connection Nomenclature" and see a much larger viewing area of those configurations.
Modeling Vessel / Nozzles in AutoPIPE
