Limcon is productivity-geared steel connection design software. Connection types include beam to column, brace end, member splices, anchorage to concrete, and complicated multi-member joints. By using a library of standard connection types, designers can arrive at results in a remarkably short time.
Limcon offers additional codes and connections as a companion to [[RAM Connection]], which is Bentley's premier connection design software. Use Limcon for Australian and Canadian connection checks as well as HSS to HSS connections.
Vist the Limcon Product Page for additional information on this product.
Comprehensive limit state design to a number of international standards.
Shear and moment connections, member splices, brace end connections, base plates, and hollow section connections.
Connections may be automatically designed by the program or you can specifically design them.
Concise calculation summary, reporting results for all relevant limit states.
Output to CAD format directly from design.
Download a full list [PDF] of the specific connection types available in Limcon's template library.
[[RAM Connection]]
