| Product(s): | STAAD.Offshore | ||
| Version(s): | All | ||
| Area: | API | ||
| Subarea: | N/A | ||
| Original Author: | Carlos Agura Bentley Technical Support Group | ||
STAAD.Offshore has been deprecated, however a far more comprehensive solution for the analysis and design of offshore structures is provided using the SACS product range. For details of this refer to the information:-
SACS - Offshore Structural Analysis and Design Software (bentley.com)
The following section is retained for information only.
STAAD.Offshore is a powerful suite of pre- and post processor modules for the STAAD.Pro structural analysis and design program. Comprised of two primary modules, waveload and transport.
In STAAD.Pro itself you additionally have the option of carrying out design code checks to the American Petroleum Institute (API) recommended practice for planning, designing, and constructing fixed offshore platforms with the STAAD.Pro API code check module.
