c. Flexible Joint Piping Components - Modeling Approaches, Tips, Techniques used in AutoPIPE
Attention: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Modeling Approaches> Modeling Approaches>
This help has been provided in order to give users ideas for modeling typical piping arrangements. The steps shown in each example should not be taken as the only method available to create models. In addition, the intent of the examples is to present ways to create adequate models of specific piping components for analytical purposes.
Anchor Bends
Cuts: Cold Spring
Flexible Joints
          a. Single Bellows Expansion Joint
          b. Tied Bellows Expansion Joint
          c. Tied Universal Expansion Joint
          d. Hinged Expansion Joint
          e. Gimbal Expansion Joint
          f. Slip Joint
          g. Ball and Socket Joint
          h. Pressure Balanced Expansion Joints
Frames  Hangers
Nozzles   Pipes
Reducers   Rotating Equipment
Supports  Tees
Valves  Vessels
Comments, Questions, and Answers:
  1. Flexible Joint Dialog Explained
  2. Apply define coefficient of thermal expansion
  3. Perform a "rigorous pressure extension analysis"
  4. Flexible joint material
  5. Appears that the Flexible joint are not relieving pipe stresses, why?
  6. Single line graphics
  7. How does AutoPIPE calculate the following movements reported for a skewed flexible joint?
  8. Modeling approaches:
    1. Tied-bellows example using Tie/Link supports
    2. Penetration Seal Bellows Joint
    3. Hose:
    4. Ball joint
    5. Expansion Loops
    6. Pressure Balance
    7.
Model Different Types of PIPING Components
