Applies To | |
Product(s): | AutoPIPE |
Version(s): | ALL |
Area: | Readme |
Date Logged & Current Version |
Dec 2023 23.00.01.367 |
What is New & Changed in AutoPIPE® |
The following outline identifies new features and enhancements in the AutoPIPE 2023 Edition Minor Update 1 version 23.00.01.367.
AutoPIPE® Requirements |
More detailed installation information can be found in the AutoPIPE Quick Start Guide.
Product | AutoPIPE |
Version | v.23.00.01.367 |
Language |
PCF Translator | v.1.3.1.367 |
PDS Translator | v.6.0.0.021 |
ADL Pipe Translator | v.1.0.0.029 |
ME101 Translator | v.1.0.0.007 |
Structural Property Catalog | 10.00.00.015 |
Bentley DGN Preview Handler | 10.17.01.556 |
Bentley DGN Thumbnail Provider | 10.17.01.11 |
iTwin Analytical Synchronizer | v.23.01.02.64 |
iTwin Service Add in V2 | 2.6.1.1 |
Connection Client | 23.00.00.10 |
Microsoft SQL Server Compact 3.5 SP2 | 3.5.8080.0 |
CD drive or access to the Internet required for product installation. The minimum system configuration for installation:
Operating System |
Microsoft Windows 10 x64 Professional or higher |
.NET Framework |
4.7.2 |
When installing the product through the installer program, the required components will be installed automatically. The contents of the Desktop Prerequisite Pack include:
NOTE: AutoPIPE uses the following fonts on dialogs and in reports. These fonts are pre-installed with Microsft Windows. If any of these font are missing, the text on dialogs and in reports may appear smaller/larger than usual. To install missing fonts, please repair or reinstall Microsoft Windows.
The minimum recommended workstation profile for running AutoPIPE is:
Memory | 4 GB recommended. More memory almost always improves performance, particularly when working with larger models. |
Hard Disk | 4 GB free disk space (not including Restore Point space requirements). |
Video Graphics Card | Any industry-standard video card which supports OpenGL 3D graphics. |
ProjectWise |
ProjectWise Server 10.00.03.299 with ProjectWise Explorer 10.00.03.453, Note: ProjectWise Server and ProjectWise Explorer are only required if Bentley's ProjectWise is used to manage project documents. |
OpenPlant Isometrics Manager |
CONNECT Edition Update 11 - 10.11.00.175 Note: Users can use OpenPlant Isometrics Manager (OPIM) to review Stress Isometrics created by AutoPIPE without an entitlement for OPIM, provided they are opened from within AutoPIPE. Direct use of OPIM without an entitlement will log usage and may lead to charges. Click here for more information. |
Word processing, |
Compatibility is more streamlined with Microsoft® Office 64-bit. Please refer to this wiki here for installing AutoPIPE on machine with Microsoft® Office 32-bit. |
Download and Installation |
See the AutoPIPE Quick Start Guide (..\Documents\Quickstart_AutoPIPE.pdf) for more information on downloading and installing AutoPIPE.
To complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles, you will need to obtain the name of your Site Administrator by submitting a Service Request at http://apps.bentley.com/srmanager/ProductSupport.
If you are experiencing problems logging into your Bentley account, please contact Bentley at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
Network Considerations - Network drives are only supported for data files.
- AutoPIPE software must be installed on a local client workstation.
- AutoPIPE data files (*.DAT) must have full read/write access to be opened and edited.
Applications Included in the Installation Package |
AutoPIPE Standard, AutoPIPE Advanced, AutoPIPE Nuclear, and add-ons are installed from one executable.
NOTE: For further information on translators, please refer to their respective readme files.
AutoPIPE Functionality for QA Approvals |
Documentation |
Program Help: Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions. A set of supplemental How To, Tutorial, and Reference Information documents in PDF format are provided in the Supplemental Documentation folder (Bentley AutoPIPE > Supplemental Information) of the main Program Help file (autopipe.chm).
Tutorials: Documentation for AutoPIPE applications is provided online in the Adobe.pdf format. These files are accessible from the Help Menu. All documents can be browsed, searched, or printed with the Adobe Acrobat Reader. Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
Piping Codes |
This sections contains the list of piping codes, code editions supported and AutoPIPE license edition (Standard, Advanced or Nuclear) for which these items are supported.
Piping Code | Description |
B31.1 Power | Power Piping |
B31.3 Process Piping | Process Piping |
B31.4 Liquid Trans. | Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia and Alcohols |
B31.8 Gas Trans. & Dist. | Gas Transmission and Distribution Piping Systems |
EN 13480 | European Piping Code for Metallic Industrial Piping |
General | General Piping Code |
ASME B31J |
Stress intensification factors, flexibility factors, and sustained stress factors used in B31 piping analysis |
AutoPIPE Advanced includes all codes available in AutoPIPE Standard, as well as the following codes.
CSA-Z662 | Canadian Standards Association, Oil and Gas Pipeline System |
CSA-Z662 Offshore | Canadian Standards Association, Offshore Steel Pipelines |
BS 806 | Design and Construction of Ferrous Piping Installations for and in Connection with Land Boilers |
BS 7159 | Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites |
SPC-2 | Swedish Piping Code, Method 2 |
TBK5-6 | General Rules for Piping, The Norwegian Pressure Vessel Committee |
STOOMWEZEN | Dutch Piping Rule D1101 of the Rules for Pressure Vessels |
DNV Offshore | Det Norske Veritas, Rules for Submarine Pipelines |
MITI 501 3-1980 |
MITI 501 Class III Piping Code |
KHK | KHK E 012 Piping Code, Seismic Level 1 or 2 (Seismic Level 2 requires a KHK 2 Add-On license) |
RCC-M | French Piping Code for Power Industry |
SNCT | French Piping Code for Process Industry |
SNIP Russian 2.05.06-85 Oil & Gas | Russian SNIP piping code for oil and gas |
ISO 14692 | Petroleum and Natural Gas Industries - Glass Reinforced Plastics (GRP) Piping |
B31.4 Offshore | Offshore Liquid Piping Systems |
B31.8 Offshore | Offshore Gas Transmission |
B31.12 Hydrogen Industrial Piping | ASME B31.12 Hydrogen Pipelines (Section IP) |
B31.12 Hydrogen Pipelines | ASME B31.12 Hydrogen Pipelines (Section PL) |
AutoPIPE Nuclear includes all codes available in AutoPIPE Standard and AutoPIPE Advanced, as well as the following codes.
ASME NB Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 1 Components |
ASME NC Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 2 Components |
ASME ND Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection ND, Class 3 Components |
ASME NCD Nuclear | Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NCD, Class 2 and Class 3 Components |
JSME PPC Nuclear | JSME S NC1: Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping |
How to Activate AutoPIPE® |
Subscription Entitlement Service is Bentley's licensing model, providing enhanced security and optimized value for your Bentley Subscriptions. It is integrated with Bentley's Identity Management System (IMS) to allow near real-time reporting of usage, improved alert messaging to users and increased administrative capabilities to license administrators in your organization. It will not only give you more options to monitor and manage usage but also provide new, advanced licensing features that will enhance digital workflows.
With Subscription Entitlement Service, all users must be registered with Bentley's Identity Management System (IMS) and sign in to the CONNECTION Client to access Bentley applications. Product activation will now occur through user sign-in to the CONNECTION Client with a valid IMS ID associated with their account. User sign-in will replace traditional activation keys, offering enhanced security as administrators will be able to control which users have access to Bentley software. License entitlements are granted and maintained through Subscription Entitlement Service's Entitlement Management Service. By signing into the CONNECTION Client users can also find their organization's projects, download software updates, receive relevant notifications, and track their usage.
Subscription Entitlement Service features the new license alerts notifications that can be set by an organization's license administrators to let the users know when they reach a set usage threshold. These notifications will alert the users that if they continue to use the product, a term license may be issued. The user in such a situation has the choice to quit the application before a license is used or acknowledge that a term license may be generated and proceed with starting the application, based on what settings the administrator chooses.
The product will run in evaluation mode.
Go to www.bentley.com to request activation information.
For SES Licensing:.
AutopipeSetup.exe -s -LicenseType=Connect
Error History |
The following outline identifies all major errors fixed in Release of AutoPIPE v23.0.1.
If a sustained combination includes another combination at the stress level, AutoPIPE may incorrectly calculate a higher sustained load margin value than allowed for use in thermal combinations. This would result in a higher allowable stress being reported for thermal loads, leading to unconservative results.
Unsigned load cases or combinations, such as Response Spectrum, are not correctly applied to tee nodes where the in-plane and/or out-plane moment axes are negative to the global coordinate system. If the combination combines a signed load case and dynamic load case, and the combination method is summation, the combination will be unconservative if the signed load case is positive. If the combination method is subtraction, the combination will be unconservative if the signed load case is negative.
AutoPIPE does not provide option to input the crotch radius and thickness values for Welding and Contour tees. Moreover, AutoPIPE uses the Flexibility Characteristic equation which is applicable only when the crotch radius and thickness limitations are being met. In situations in which the crotch radius and thickness limitations are not met, incorrect Flexibility Characteristics will be calculated leading to incorrect SIF calculations.
The In-Plane SIF calculation for the Fitting Tee is not in accordance with the 2017+2021 addenda of the EN13480 European Code when the "Single SIF at point" option is unchecked in the Result Model Options.
The Ultimate Force Gap inputs for a new Incline Support inserted in a model may incorrectly get linked to one or more previously available Incline Supports in the model. Modifying Ultimate Force Gap inputs for any one of the linked Incline Supports will update the corresponding inputs for other linked supports in the model. This behavior may cause unintentional changes to the support inputs and lead to incorrect, possibly unconservative Displacement, Forces, Moments, and Stress results.
Material density for certain standard materials provided with ASME Nuclear material libraries are not exactly the same as provided by ASME Section II part D. Historically, these density values were gathered from various sources. The percentage difference between the density values ranges from a minimum of -3.37% to a maximum of 4.33%.
The occasional load margin may not be used correctly for thermal allowable values. This occurs when the units for the model are set to any other units than English or AutoPIPE. In cases where the sustained allowable results in the minimum margin for a point, program may ignore that margin and use a larger margin from occasional load combinations. Using the higher allowable will result in unconservative allowable for thermal load combinations.
ASME B31.4: Longitudinal Pressure term may not get added to sustained stress. This happens only when result model option "Use rest. long code eq." is checked and code compliance output report is generated via keyboard shortcut "CTRL+B". This defect only impacts B31.4 2009 and later code editions having result model option "Use rest. long code eq." enabled.
Tee local transformation is required by all codes to align the load directions with stress intensification factors for tees. Previously, AutoPIPE performed this transformation after modal and group combinations were performed on dynamic loads (for example, response spectrum may have multiple modes to combine together to get a single total response). These combinations typically result in unsigned values, of which can no longer be transformed.
Flexible joints transformation matrix used to convert displacements from global to local coordinates is malformed. This transformation skews the flexible joint report results in a way that do not reflect the actual displacements.
Program does not consider B31J Reducer SIF requirements (as per Table 1-1, sketch 3.1) for B31.4 Onshore 2019 edition, with B31J checked. However, the same capability is implemented as per B31J requirements for other piping codes (such as B31.1, with B31J enabled).
For ASME B31E combinations/categories, when operating load case selected in seismic B31E dialog is from the first analysis set e.g., T1[1], Pressure stress (PD/4t) is not included or incorrectly included from another analysis set based on temperature case in sustained stress calculations. Also, allowable and yield stress is incorrectly selected from another analysis set for calculation of sustained allowable. This will lead to incorrect, possibly unconservative, sustained stress and sustained allowable results for the model.
The flexible joint output subreport is intended to display the deflections (translations and rotations) that occur across the flexible joint itself. Currently, AutoPIPE is doing this by transforming the global displacements (as shown in the Displacements report) into a coordinate system that is local to the flexible joint as designed. This can lead to incorrect results when the deflections are not occurring across the flexible joint, e.g. a thermal anchor movement somewhere else in the system. This imparts displacements, but not across the flexible joint.
Updated Power Platform to version 23.0.1 that fixes security vulnerability CVE-2023-0286.
Updated Power Platform to version 23.0.1 that fixes security vulnerability CVE-2023-31038.
Updated Power Platform to version 23.0.1 that fixes security vulnerability CVE-2023-45853.
Updated Boost libraries to fix security vulnerability CVE-2012-2677.
Copyright |
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
© 2023, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the product installation folder.
Corporate Headquarters Bentley Systems, Incorporated |
Bentley EMEA Bentley Systems International Limited |
Bentley Asia Bentley Systems (Beijing) Co., Ltd. |
Online Information |
requires access to the Internet
How do I download, install, and license AutoPIPE?
