| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
Problem:
When I open a file from ProjectWise server, STAAD.Pro crashes; when I opened the same file from my C: drive, it runs fine.
STAAD.Pro creates a number of auxiliary data files in the same folder as the STAAD model. There are instances when some of these files get locked up or get corrupted. As a result, the model may fail to open, and the software may crash.
To resolve this, try the steps as stated here:
Create a new folder in the ProjectWise server. Copy ONLY the .std file from your "C:\" into the new folder.
Launch STAAD.Pro and try to open the model. It should open fine.
If you still cannot open the file, please create a service request.
