Pressure Vessels Enhancements and Defects
See the following list of AutoPIPE Vessel's known Enhancements and Defects that have already been logged:
ADO
IDEA APV-I-44 :
Nozzle loads to be considered for Vessel Supports and Foundation calculations
Bug 1557759 :
ASME VIII div.2 - Flange Stress Factors (F,V,f) should not be the same as those for Div.1
Feature 639041:
Addition of Australian AS1210 Code
Feature 638875:
Horizontal Vessels: detailed report of stresses at every section (Wind/Seismic Loads) similar to vertical vessels
TFS
Enhancement 746579:
Corrosion Allowance for Saddles
Enhancement 157375:
Skirt thickness calculation - Local load analysis for skirt to compression ring (anchor) connection
Bentley AutoPIPE Vessel
