| Product(s): | AutoPIPE Vessel | ||
| Version(s): | 44.00.01.014 | ||
| Area: | Error | ||
The following occurs when I perform the Strength Calculations:
Errors:
Error Code 331 - NOZZLE N1: Weld sizes are not adequate.
How to fix it?
In the MAP condition, the check does not consider corrosion which is applied to the shell in operating condition only (3.2mm).
Calculation goes then as follows for the MAP Condition:
Min Required weld = min (6mm, Shell thickness *0.7) = min (6 mm, 9.52*0.7) = 6mm
Then the nozzle weld is 8.5mm (imposed by user) *0.7 = 5.95 mm
Then 5.95 mm < 6mm so it flags.
UW16 for the MAP conditions is not edited, just internally checked. That's why we do not see the reason of error in the report.
In new condition the minimal required thickness is 6mm. You can increase the 8.5mm of weld by a little (8.6 mm is enough).
In the corroded condition:
Shell thickness = 9.52 -3.2 = 6.32mm
Min Required weld = min (6mm, 6.32 *0.7) = 4.424 mm
Then 5.95mm > 4.424 mm. This is what we see in the report.
