General reading error in RCDC, Input table or Frame Assignments-output stations
Product(s):STAAD Advanced Concrete Design
Version(s):Connect Edition
Environment:
Area:Concrete Design
Subarea:General
Original Author:Ranjana, Bentley Technical Support Group
When trying to import Etabs file into RCDC , getting error of input table or frame assignment missing
So in this case we can ask you to check for the table list before exporting in Etabs and generating the .mdb or the .accdb file  as mentioned below .
Sr No.Tables
1Area Assignments - Pier Labels
2Area Assignments - Section Properties
3Area Assignments - Summary
4Area Load Assignments - Uniform
5Area Section Property Definitions - Summary
6Beam Bays
7Beam Connectivity Data
8Brace Bays
9Column Bays
10Column Connectivity Data
11Element Forces - Beams
12Element Forces - Braces
13Element Forces - Columns
14Frame Assignments - End Length Offsets
15Frame Assignments - Insertion Point
16Frame Assignments - Releases and Partial Fixity
17Frame Assignments - Summary
18Frame Section Property Definitions - Concrete Circle
19Frame Section Property Definitions - Concrete Rectangular
20Frame Section Property Definitions - Steel Angle(Optional)
21Frame Section Property Definitions - Steel Channel(Optional)
22Frame Section Property Definitions - Steel I/Wide Flange(Optional)
23Frame Section Property Definitions - Steel Plate(Optional)
24Frame Section Property Definitions - Steel Tee(Optional)
25Frame Section Property Definitions - Steel Tube(Optional)
26Frame Section Property Definitions - Summary
27Grid Definitions - General
28Grid Definitions - Grid Lines
29Joint Assignments - Restraints
30Joint Design Reactions
31Load Case Definitions - Summary
32Load Combination Definitions
33Load Pattern Definitions
34Material Properties - Concrete Data
35Material Properties - General
36Pier Forces
37Point Bays
38Point Object Connectivity
39Slab Property Definitions
40Spandrel Forces
41Story Definitions
42Story Drifts
43Story Forces
44Wall Bays
45Wall Connectivity Data
If all the tables are selected properly and in order then your issue should be resolved .
