| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Crash |
| Date Logged & Current Version | Aug. 2023 23.00.00.230 |
When modifying Material Library selection on General Model Options AutoPIPE crashes, and message inside of log file reads: "<fatal> IORREA: File read error", why?
As of Aug 2023, there is only one reported issue of this occurring. The issue was directly related to customize material library file. The user tried extending the material library MATL data table beyond the currently limits of that library. There is a hard limitation of 231 cells in the MATL data tables for each material.
See the following image, the sum of all the data cells in a default library was 229, however the customize material library tried to extend the table a total number of 274 ( >231) cells.
Again, at this time, the hard table size is 231. Once the customize library Matl data tables were reduced below 229, there was no issues of using the customize library.
If users would like to see this limitation raised higher than the current limit, please use instructions here to first search for an existing IDEA and up vote it / or post a new IDEA.
General / Edit / Results Model Options mod crashes program
