Notes: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Bug 1990173
B31.1 1986& 1973 Libraries: Reference standard material for some carbon steel specifications incorrectly refer to low carbon instead of high carbon for Modulus of Elasticity
Bug 1967667
ASME, B31.3 & B31.1 Libraries: Reference standard material for some carbon steel specifications incorrectly refer to low carbon instead of high carbon for Modulus of Elasticity
Bug 1346363
Flange Bolt library: correct course thread library values from standard B1.1 2003 Tables 6, 7, and 11
ADO
TFS
Defect 854258
HDPE Pipes are not accepting nominal size 1.5 inch in pipe properties
Enhancement 709088
Add new valve catalog / library for Velan
Enhancement 696066
Add table to Beam Section Profile Database dialog to display a fraction of beam properties before selecting
Enhancement 696051
Add solid square shaped to beam library
Enhancement 672545
Add GOST 32388 code approved materials to B31.3 material library
Enhancement 346476
No warning provided by the program when the thickness selected for a specification exceeds allowable thickness range and fall below the allowable thickness range
Enhancement 368968
Add EN 1092-1 flange library
Enhancement 208153
Add New 1.0565 Material to EURO2002, EURO2009 and EURO2012
Enhancement 205025
Updated outdated AUTOFRP library
Enhancement 110638: Tracker#: 3310
Add solid pipes to beam library
Enhancements Requests and Logged Defects
