| Product(s): | RAM Elements | ||
| Version(s): | 16.07.00.248 | ||
| Area: | Licensing | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group |
When I click optimize or try to check in Continuous Beam module, I'm getting an error ' RAMFE.dll not registered ' RAM Elements analysis is not working as well, I'm getting the same error message.
RAMFEA components are not installed in the machine.
Please uninstall RAM Elements and reinstall it. This should install the RAMFEA components.
