| Product(s): | RAM Structural System | ||
| Version(s): | All | ||
| Area: | Installation/Licensing Solutions | ||
| Subarea: | General | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
I am having issues when selecting members in the 3D modules. This is a Mac machine that has a Windows partition.
If you are using an old version macOS please update it to the latest version. This should resolve the issue.
If the issue persists, update your video card drivers in your MacBook. Also changing the hardware acceleration might help; you may have to change the resolution to lower than the default setup.
