The base version is in English but the UI and the Report can be switched into other languages due to the use of a dictionary file installed with the program. This language dictionary can be selected under Menu> Preferences.
Language to include: C
| German | French | Russian |
| English | Croatian | Portuguese |
| Spanish | Polish | Chinese (Simplified) |
| - | _ | _ |
Note: General help is only available in English.
Newer version are now released as Multi Language versions, see section above.
Technical information: Release Notes, Product Data Sheet, etc..
