| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | installation |
| Date Logged & Current Version | April 2022 AutoPIPE Vessel 42.04.00.092 - AutoPIPE 12.07.00.346 |
The following appears when installing the application:
English Translation:
Windows functionalities
One application of your PC need the following Windows functionality:
.NET Framework 3.5 (including .NET 2.0 and 3.0)
Download and install this functionality
Window will obtain the archives it needs in Windows Update and will finish installation
Ignore this installation
How to avoid the issue?
For most of the earlier Windows versions, .Net Framework could be installed externally as needed. However for newer versions of Window, .Net framework is packaged within Windows. See steps below to activate the application now:
On the computer that is installing the application, open Windows "control panel", then open Windows "Programs and Features" command.
Then, click on the "turn windows features on or off"
In the listing find option for .Net Framework 3.5 and enable it.
Close this dialog, reboot the computer and try to install AutoPIPE software again.
IF this does not resolve the issue, use instructions found here:
Install .NET Framework 3.5 on Windows 11, 10, 8.1, 8 - .NET Framework | Microsoft Docs
Download, Installation, Uninstall - Bentley AutoPIPE Vessel
