| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | |||
| Original Author: | Ranjana, Bentley Technical Support Group | ||
RCDC will import only the Access Database (.accdb) type of file which will be created from ETABS version 2018.
For creating the .accdb file,
Go to File- Export - ETABS table to Access.
Under the Table for exporting to access, select table as per images below:
All input data i.e. Model Definition needs to be exported as per below image.
Depending upon what you are designing, select Column forces or Beam Forces or Pier forces. You can create multiple filter files with the pertinent data.
Select all basic load cases in the setting “Select Cases / Combos”. It is not essential to select the load combinations as RCDC reads only the definition of the combinations and not the forces for the same. The forces for the combinations are computed during design time.
Note:
