03. Component Data Listing (Model Input Listing) FAQ in AutoPIPE
Select the following hyperlink for issues on the respective Model Input listing (or Component Data listing) report:
Note, this report has been removed from AutoPIPE 12.05 - 12.06. However this report has been added back into AutoPIPE 12.07.00.346 and higher. This version of the program and higher added the ability to generate an Extended Components Report (.RPT) as a Quick Report only and display it in the Text Report Viewer. One may then save, open, import, etc.. the RPT file like any other text file. This report is provided as is and will not have any further development.
Reports - AutoPIPE
