| Product(s): | STAAD Advanced Concrete Design | ||
| Version(s): | Connect Edition | ||
| Environment: | |||
| Area: | Concrete Design | ||
| Subarea: | General | ||
| Original Author: | Ranjana, Bentley Technical Support Group | ||
The minimum strength of the column is checked in RCDC as per 18.7.3. (Flexural joint check of the column).
a separate report is available for the joint check. A sample report is attached for reference.
