Nozzles, Flanges and Gaskets
Flange:
Flange Optimization
Flange Bolt Tensioning
Optimize Body flange design
Number of bolts required for design using
Why the calculation of bolts is set by default on the dialog and then imposed by the code to calculate the section
Why Corrosion Allowance on the Component Properties dialog in is grayed out
Flange calculations does not consider corrosion allowance and the flange facing height
Design a custom flange on a nozzle
WRC for Nozzle on blind flange
Overcome Body Flange type error with gasket made of vegetable fiber using Annex G for controlling the bolt stress
Optimizes flanges
Welded and Flange calculations grayed out on the Standard flange tab
"Use En 13445 AnnexG/En 1591" option grayed out on the Body Flange tab
Add B16.47 Series B flanges for sizes above DN600
How can we calculate the stub end thickness in loose type flanges?
Gasket and Bolt calculations for "H" and "Hp" values are incorrect, why?
Nozzle:
Model a nozzle
Model Nozzle on Nozzle:
Discussion #1
Discussion #2
Model "LIP type Nozzle"?
Model a nozzle on the bottom of a tank
Model / design Nonstandard flanges on standard Nozzles
Model a nozzle attached directly to cone small diameter end
Model offset for a nozzle on a Nozzle Bolted Cover
Model nozzle on head
Model a reducer on the nozzle
Model customize nozzle standard such the projection depends on the insulation thickness
Model different standards for projection nozzles with one mouse click
Nozzle Neck Thickness Calculation as per ASME Section VIII Div.1 UG-45
WRC 107/297 local loads: weld joint efficiency equal to 1
Nozzle loads added in the 6 related fields are not matching the table in the Nozzle Loading file
Set nozzle projection from the insulation surface
Understand reported variable 'd' and 'di'
"Set-in" nozzle option was not reported but indicated on dialog
Different results for nozzles between versions of software
Different nozzle opening reinforcement formulas in software compared to ASME Section VIII Div. 1 code
Nozzle Flange Description
Nozzles design check report missing
Reported nozzle's Di (inside Diameter) value different than program dialog
Nozzle fillet radius calculation using WRC
Gasket:
Gasket Material Database and Customization
Why we are unable to use Tapered Gasket (Seal Ring)? facing an error while performing analysis.
Gasket and Bolt Calculation, what is DL in
Miscellaneous:
Modify external pressure ring stiffener type and size
Model internal piping
Model transition opening offset
Support Solutions and FAQ's
System Messages (ex. Error, Warning, etc..)
Bentley AutoPIPE Vessel
