Warning Messages
23 - Tubesheet Loading conditions xx [corroded normal condition]: Scope requirements not maintained
64 - FLANGE (nozzle XX): Rating, material group not specified in material database file
69 - FLANGE (nozzle XX): Flange not listed
126 - CHECKING ONLY (NO DESIGN): check warning message in calculation note.
127 - CHECKING DATA : Compartment number > 3.
159 - Nozzles: no verification on multiple openings. warning message in AutoPIPE Vessel
232 -
CHECKING DATA : Foundation height = xx.xx in , by default
233 - CHECKING DATA : Maximum total deflection under wind action = H/240 , by default (Operating).
312 - NOZZLE xx: the external projection may not be sufficient (minimum=xxx mm).
344 - TORISPHERICAL HEAD (xxxx): no check according to AD B3.
360
FLANGE BF: the required space under the bolt is not available ( required=xx mm ; actual=xxxx mm ) (see: files boltISO.xlsx and/or boltUN.xlsx).
365
FLANGE BC: the required space above the bolt is not available ( required=xx mm ; actual=xxxx mm ) (see: files boltISO.xlsx and/or boltUN.xlsx).
369 - FLANGE 25.01: the hub thickness ratio is > 4.5
385
BUNDLE: the SID for the bundle calculation is different from the diameter imposed by the geometry...
496 - Tubesheet : Fixed Tubesheets (or junctions with shell/channel) are different (the Tubesheet calculation is based on the front box sheet data).
580 - SADDLE No. 1: this saddle is not located on a cylindrical shell (xx.xx).
589 - FLANGE (nozzle XX): the rating class is less than required rating class (XX)
604 - Unit Distortions on Nozzles (xxx): PD 5500 Figure G.2.2-19 deflections of cyl. shells due to radial loads, values beyond curve boundaries .... appears in AutoPIPE Vessel
609 - TEST: a test pressure is less than the required value.
663 - MATERIALS : a temperature (xxx °C) is less than the minimum usage temperature
669
BUNDLE LAYOUT: the actual value of OTL (xx.xx mm) is not equal to the input value (xxx.xx mm) used for the calculation
702 - TEST : governing condition, the thickness of one or more components needs to be increased only under the test condition. The MAWP adopted has been reduced to a value lower than the maximum permitted pressure.
758- NOZZLE xx: values beyond table limits (xxxx).
768
ROOF: the roof is not frangible.
884 - The platform (PTF) is located above the vessel, the loads (weight and loaded area) are applied to the last section.
944 - GEOMETRY (Flange): This component cannot be considered a Standard Pipe due to the type of material. It should be "Seamless Pipe", "Welded Pipe", or "Fitting". The dimensions might not conform to the Standard.
1011 - Allowable compressive stress [EN 13445-3 16.14.8] : Using fabrication tolerance quality class C and taking factor ψ = 0.75 is a conservative assumption for vessels that satisfy the manufacturing tolerance requirements of EN 13445-4, Clause 6.
1024
EN 13445 Annex G / EN 1591 : FLANGE 31.06: the nominal design stress of bolts must be determined by the same rules as used for nominal design stress of flanges and shells.
Confirm the license change
Probes : Views not fully filled: Warning messages in AutoPIPE Vessel
You will be unable to save
Warning Message- "Wrong estimate Param File: c"
Warning Messages, Unregistered Messages, Error Messages, or Application Crash issues
AutoPIPE Vessel
