Example:
The +1, +2, are typically associated with soil points that occur between actual node point of the model.
Example:
In the image above A05 F is the far point of a bend, and +1, +2, etc.. are soil points spaced as defined on the Soil tab of the input grids.
In 2021 AutoPIPE added a new function to see intermediate soil node points, use:
Use these commands in order to better view and understand report information.
Output Results appear to be both (+)ve and (-)ve at the same point in AutoPIPE, why?
