| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | Report | ||
| Date Logged & Current Version | Jan 2015 09.06.01.10 |
What does (node number) + / - mean in AutoPIPE's output reports?
example:
Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Results Interpretation> Pipe Forces and Moments: Global Option
Output Results appear to be both (+)ve and (-)ve at the same point in AutoPIPE, why?
Node number with suffix N+. N-, M+, M-, F+, F-
Point suffixes +1 ,+2 , etc. mean
