In the assessment of possible crack growth in structures such as power plants, heavy machinery and airplanes, the computation of stress intensity factors along 3D cracks using linear elastic fracture mechanics is extremely important.
Traditionally, the J-integral and stress intensity factors are calculated using a virtual shift technique based on nodal point virtual shifts, in which a mapped mesh is required around the crack front. However, for complicated components, it is frequently challenging to construct a mapped mesh around the crack front.
In ADINA System, 3D fracture mechanics calculations were significantly improved by the introduction of the SVS method of fracture mechanics. The SVS (station virtual shift) method includes the following features:
Because it is not necessary to construct a mapped mesh around the crack front when the SVS method is used, the amount of effort required to perform linear elastic fracture mechanics analysis is considerably reduced.
One fundamental idea used in the SVS method is that virtual shift domains are mesh-independent. As a consequence, when the fracture results are output at equally spaced crack advance stations, these stations are also mesh-independent, thus as the mesh is refined, the fracture results can be expected to become more accurate.
In the current Tech Brief, we use the SVS method. This allows us to use a free-form mesh everywhere, and to calculate both the J-integral and the stress intensity factors.
Figure 1 shows the nozzle geometry along with a surface crack:
Figure 1 Nozzle geometry along with surface crack
Cracked model definition
The cracked model is constructed as illustrated in the following figures.
| Figure 2 Nozzle without any crack. The ADINA-M module of the AUI is used for the geometry definition. | Figure 3 Crack front line and the crack body (body that will eventually contain the crack). At this point in the model definition, the crack body partially overlaps the nozzle, and the crack front line extends outside of the nozzle. |
Figure 4 The result after intersecting the crack body with the nozzle body, and subtracting the crack body from the nozzle body. The crack body is trimmed to the nozzle geometry. | Figure 5 Crack body sectioned with a sheet in order to create the top crack body and the bottom crack body |
Figure 6 The result after projecting the crack front line onto the faces of the top and bottom crack bodies. The projection creates two faces for each body on the common boundary between the bodies. | Figure 7 Glue mesh and face-link definitions between the top and bottom crack bodies and the nozzle body |
Figure 9 The cracked bodies mesh along with the geometry faces on the boundary between the top and bottom cracked bodies. The cracked bodies mesh is split at the cracked faces (dark green in the figure), using the new MESH-SPLIT command of version 9.1 (see the ADINA Handbook for more information about MESH-SPLIT). | Figure 10 Rotated view for Figure 9, same view as in the following figures. |
Fracture definition
The new CRACK-SVS command of version 9.1 is used to define the SVS virtual shifts. The input for the CRACK-SVS command consists of
Figure 11 shows the SVS virtual shifts created by the CRACK-SVS command and Figure 12 shows the SVS virtual shift symbol.
Figure 11 SVS virtual shifts | Figure 12 SVS virtual shift symbol |
Figure 13 shows some of the elements near the crack front along with the virtual shifts. The SVS domains are independent of the meshing and the crack advance stations do not coincide with nodes.
Figure 13 SVS domains and some of the elements near the crack front
Results
The following results are calculated by ADINA Structures:
Figure 14 J-integral vs distance along crack front
Figure 15 Stress intensity factors vs distance along crack front
The results for the first and last virtual shifts are not shown, since these virtual shifts correspond to shifts at the end of an open crack front, and the results from these shifts are not as accurate as the other virtual shifts. One reason for this inaccuracy is that the virtual shift domains for the ends of the open crack front are not entirely contained within the mesh.
The stress intensity factor results clearly show that mixed-mode conditions are present on the crack front.
Both the J-integral values and the stress intensity factor values are nearly independent of the radial domain chosen.
Clearly the SVS fracture capabilities of ADINA represent a significant advance.
See also:
