Pushing Loads from STAAD.Pro to the iTwin Analytical Synchronizer
Load Case Objects
STAAD.Pro Load Cases and Combinations are pushed to the iTwin Analytical Synchronizer as Load Case objects.
NOTE: Load Groups (i.e. Reference Load Cases) defined in STAAD.Pro will not be pushed to the iTwin Analytical Synchronizer.
Load Objects
STAAD.Pro Load Items are pushed to the iTwin Analytical Synchronizer as Load objects.
NOTE: Loads defined with a Load Definition in STAAD.Pro will not be pushed to the iTwin Analytical Synchronizer.
