STAAD.Pro Surfaces are pushed to the iTwin Analytical Synchronizer as Surface Member objects.
STAAD.Pro Surface Properties and Specifications can be viewed for each Surface Member object in the iTwin Analytical Synchronizer.
iTAS Surface Member Property | STAAD.Pro Surface Properties and Specifications | |
Load Resistance | All structural surfaces pushed from STAAD.Pro will automatically be defined as Gravity and Lateral in the iTwin Analytical Synchronizer. | |
Placement Surface |
Indicates the Alignment assigned to each surface in STAAD.Pro. |
Thickness | Indicates the Thickness assigned to each surface in STAAD.Pro. | |
Use | Indicates the Attribute assigned to each surface in STAAD.Pro. | |
Material | Indicates the name of the Material assigned to each surface in STAAD.Pro. | |
All materials listed on the Catalog tab in the STAAD.Pro Physical Modeler will be pushed to the iTwin Analytical Synchronizer.
Concrete | Steel |
Concrete materials defined in STAAD.Pro will be pushed to the iTwin Analytical Synchronizer as Concrete Objects. |
Steel materials defined in STAAD.Pro will be pushed to the iTwin Analytical Synchronizer as Steel Objects. |
