STAAD.Pro Members are pushed to the iTwin Analytical Synchronizer as Curve Member objects.
STAAD.Pro Member Properties and Specifications can be viewed for each Curve Member object in the iTwin Analytical Synchronizer.
iTAS Curve Member Property | STAAD.Pro Member Properties and Specifications | |
Load Resistance | All structural objects pushed from STAAD.Pro will automatically be defined as Gravity and Lateral in the iTwin Analytical Synchronizer. | |
Axial Behavior |
Indicates the Axial Behavior assigned to each member in STAAD.Pro:
Placement Point | Indicates the Alignment assigned to each member in STAAD.Pro. | |
Use | Indicates the Attribute assigned to each member in STAAD.Pro. | |
Member Fixity | Indicates the translational and rotational Releases assigned to the ends of each member in STAAD.Pro. | |
Material | Indicates the name of the Material assigned to each member in STAAD.Pro. | |
Section | Indicates the name of the Section assigned to each member in STAAD.Pro. | |
All sections listed on the Catalog tab in the STAAD.Pro Physical Modeler will be pushed to the iTwin Analytical Synchronizer.
Standard Sections | Prismatic Sections |
Standard sections defined in STAAD.Pro will be pushed to the iTwin Analytical Synchronizer as Table Section Objects. |
Prismatic sections defined in STAAD.Pro will be pushed to the iTwin Analytical Synchronizer as Parametric Section Objects. |
All materials listed on the Catalog tab in the STAAD.Pro Physical Modeler will be pushed to the iTwin Analytical Synchronizer.
Concrete | Steel |
Concrete materials defined in STAAD.Pro will be pushed to the iTwin Analytical Synchronizer as Concrete Objects. |
Steel materials defined in STAAD.Pro will be pushed to the iTwin Analytical Synchronizer as Steel Objects. |
