01. What piping codes are available in AutoPIPE?
The list is constantly being updated. In order to know what piping codes are available in a specific version of the application, please see the following AutoPIPE help section in your version:
1. Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations>
2. Help > Contents> Contents Tab> Getting Started> Revision History
Or
3. See the program's  Release Notes
There are over 20+ Piping codes available in AutoPIPE:
Note:
1. As mentioned, this list will vary between different versions of the program.
2. If a specific code is missing, see WIKI here.
PIPING Code
Edition
First AutoPIPE Version Including the Code
(Persistent in Later Versions)
ASME B31.1 Power
Power Piping
  2024 Added in 25.00.01.213
2022 Added in 23.00.01.367
2020 Added in 12.07.00.346
2018 Added in 12.01.00.09
2016 Added in 11.01.00.17
2014 Added in 09.06.02.06
2012 Added in 09.06.00.15
2010 Added in 09.04.00.19
2007 + 2009 addenda Added in 09.03.00.08
2007 Added in 09.01.01.02
+ 2005 addenda Added in 09.00.00.08
2004 Added in 08.06.00.12
2001
Removed in 08.06.00.12
Added in 06.03.11
1992 Added in 08.06.00.12
1986 Added in 09.02.00.11
1973 Added in 24.00.00.231
1967 Added in 06.03.11
ASME B31.3 Process
 Process Piping
  2022 Added in 24.00.00.231
2020 Added in 12.08.01.010 (12.08.00.063 - deprecated)
2018 Added in 12.03.00.17
2014 Added in 10.00.00.10
2008 Added in 09.03.00.08
2006 Added in 09.01.01.02
2004
Added back in 09.04.00.19
Removed in  09.01.01.02
Added in 08.09.00.14
2002
Removed in 08.09.00.14
Added in 08.05.01.11
2001
Removed in 08.05.01.11
Added in 06.03.11
ASME B31.4 Liquid Trans.
Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia and Alcohols
  2022 Added in 26.00.00.306
  2019 Added in 23.00.00.230
2016 Added in 11.00.00.22
2009 Added in 09.06.00.15
2006 Added in 09.05.00.21
2002
Removed in 09.05.00.21
1998
Added in 06.03.11
ASME B31.4 Offshore
Chapter IX Offshore Liquid Piping Systems
2002
ASME B31.8 Gas Trans. & Dist.
Gas Transmission and Distribution Piping Systems
  2020 Added in 23.00.00.230
2018 Added in 23.00.00.230
2007 Added in 09.02.00.11
2003 Added in 08.06.00.12
2002
2000
Added in 06.03.11
ASME B31.8 Offshore
Chapter VIII Offshore Gas Transmission
2003 Added in 09.02.00.11
2000
Removed in 09.02.00.11
ASME B31.12
Standard on Hydrogen Industrial Piping (Section IP) and Pipelines (Section PL)
  2019 Added in 23.00.01.367, Added support for using Option B for Hf calculations
2019 Added in 12.05.00.16
ASME B31E
Standard for the Seismic Design and Retrofit of Above-Ground Piping Systems
  2008 (with 2010 addenda) Added in 23.00.00.230
ASME B31G
Manual for Determining the Remaining Strength of Corroded Pipelines
  TBD
ASME B31J
Stress Intensification Factors, Flexibility Factors, and Sustained Stress Factors used in B31 Piping Analysis
  2023 Added in 24.00.02.243
2017 Added in 12.02.00.08 (with errata)
En13480 European Code
European Piping Code for Metallic Industrial Piping
  2024 Added in 26.00.00.306
2017 + A4 2021 Added in 23.00.00.230
2017 Added in 12.02.00.14
2012 Added in 09.06.01.10
2002 + 2010 addenda Added in 09.06.01.10
2002 Added in 06.03.11
ASME NB Nuclear
Boiler & Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components Division 1, Subsection NB, Class 1
2021 Added in 23.00.01.367
2017 Added in 12.00.00.14
2015 Added in 11.00.00.22
2013 Added in 09.06.01.10
2010 + 2011 addenda Added in 09.06.01.10
2010 Added in 09.06.01.10
2007 + 2008 addenda Added in 09.06.01.10
2007 Added in 09.03.01.07
2004 Added in 09.01.01.02
2001 Added in 09.01.01.02
1998 Added in 09.01.01.02
1995 + 1997 addenda Added in 09.01.01.02
1992 + 1994 addenda Added in 09.01.01.02
1989 + 1989 addenda Added in 09.01.01.02
1989 Added in 09.02.00.11
1986 + 1988 addenda  Added in 09.01.01.02
1983 +1983 W addenda
1980 + 1982 W addenda Added in 09.01.01.02
1977 Added in 09.01.01.02
1974 + 1975 W addenda Added in 09.01.01.02
1972 + 1972 W addenda Added in 09.01.01.02
ASME NCD Nuclear
Boiler & Pressure Vessel Code, Rules for Construction of Nuclear facility Components Division 1, Subsection NCD, Class 2 and Class 3 Components
ASME NC Nuclear
Boiler & Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components Division 1, Subsection NC, Class 2
2001 + 2003 addenda
2001
Added back in 09.01.01.02
Added in 06.03.11
1995 + 1997 addenda
1992 + 1994 addenda
1992
1989 + 1989 addenda
1983 + 1983 W addenda Added in 09.01.01.02
1981 W addenda
Added in 06.03.11
1980 + 1982 addenda
Removed in 09.03.00.08
1980 + 1980 S addenda  Added in 09.03.00.08
1977
ASME ND Nuclear
Boiler & Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components Division 1, Subsection ND, Class 3
2001 + 2003 addenda Added in 09.02.00.11
2001
Added in 06.03.11
1992
Removed 09.01.01.02
S 1982 addenda
Added in 06.03.11
1980 + 1982 addenda
ASME NM1
Fiber-Reinforced Thermosetting-Resin Piping Systems
2022
Added in AutoPIPE 26.00.00.306
ASME NM2
Glass-Fiber-Reinforced Thermosetting-Resin Piping Systems
2020
 Added in AutoPIPE 24.00.01.152
HDPE CC N-755-1
ASME Code Case N-775-1 Use of Polyethylene (PE) Class 3 Plastic Pipe  Section III, Div I ans Section XI
Choose B31.1, B31.4 onshore, B31.8 onshore and ASME NC Nuclear and ASME ND Nuclear piping codes, 2004 editions and later piping code and then enable " Include ASME CC N-755-1 (HDPE)" check box.
  2011 Added in 09.06.00.15
JSME S NC1-PPC
Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping
  2008 Added in 09.05.00.21
2005 Added in 09.01.01.02
BS 806
Design and Construction of Ferrous Piping Installations For and In ion with Land Boilers
  1993
BS 7159 Glass R. Plastic
Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites
  1989 Added in 06.03.11
ISO 14692
Petroleum and Natural Gas Industries, Glass-Reinforced Plastics (GRP) Piping
  2017 Added in 12.06.00.048
  2002 + 2005 addenda Added in 09.05.00.21
SPC-2
Swedish Piping Code, Code for Piping in Stationary Plants Stress Analysis - Method 2
  1978 Added in 06.03.11
TBK 5-6
Norwegian Pressure Vessel Committee, General Rules for Piping Systems
  1990 Added in 06.03.11
Stoomwezan
Dutch Piping Rule D1101 of the Rules for Pressure Vessels
  D1101 / 1978 -10 Added in 06.03.11
DNV Offshore
Norwegian Piping Code, Rules for Submarine Pipeline Systems
  2021 DNV-ST-F101, Added in 24.00.00.231
  2017 Added in 12.04.00.13
1981 Added in 06.03.11
CSA-Z662
Canadian Standards Association, Oil and Gas Pipeline Systems
  2023 Added in 25.00.00.299
2015 Added in 10.00.00.10
2011 Added in 10.00.00.10
2007 Added in 09.03.00.08
1999 Added in 06.03.11
CSA-Z662 Offshore (Section 11)
Canadian Standards Association, Offshore Steel Pipelines
1999 Added in 08.05.01.11
MITI 501 Class 3
Technical Standards for Construction of Nuclear Power Plant Components - MITI Notification No. 501
  1980 Added in 06.03.11
KHK E 012 Level 1
Japanese Piping Code for Seismic Loads, Level 1
  2006 Added in 09.06.00.15
1997
Removed in 09.06.00.15
Added in 06.03.11
KHK E 012 Level 2
Japanese Piping Code for Seismic Loads, Level 2
2000
Added in 06.03.11
RCC-M
French Piping Code
  1985 Added in 06.03.11
SNCT
French Piping Code
SNIP 2.05 06-85 Oil & Gas
Russian Trunk Pipelines Code
  1997 Added in 09.04.00.19
General
General Piping Code
  Added in 06.03.11
Piping codes - AutoPIPE
Questions on Piping Code Calculations
